Old 10-17-2001, 12:32 AM
Leroy Leroy is offline
Default missing engine
It could be while cornering and braking the fuel in your float bowls are closing the float valve-also could be a fuel pickup in the fuel tank. you might try calling barry grant and explain the problem. I know that after changing to center hung floats that are taper at each end to solve the cornering problem, I had the same problem.I believe Barry Grant has the road race floats.
Good luck,
Lee
FORD NUT
