Old 10-05-2008, 12:12 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Weber IDA AN Fitting
I recall seeing a setup with AN fittings on a IDA installed on a BB. The carb bodies are facing in and have enough clearance for the AN fittings.
I have tried buying AN fittings to do just that but had clearance issues.
Does anyone know were I can purchase these fittings to do the exact same thing?
Or what are you guys using for fuel connections for the IDA.
If you can post pictures that would be helpful.
Thanks
