Old 10-07-2008, 06:47 AM
TIGER 6 TIGER 6 is offline
Cobra Make, Engine: SUPERFORMANCE DAYTONA COUPE, 2004, ROUSH 402R,515HP, 500 FT. LBS TORQUE
Default Starting Problems
I have Superformance's 0019 Daytona Coupe. About a year ago, I started having problems starting the car. After activating the key fob, turning the ignition key on, pushing the clutch in, and activating the "Start" toggle switch, nothing would happen. When the ignition was turned on, I could clearly hear the fuel pump come on. Pumping the clutch a few times, turning the ignition key off and on, activating the start switch etc would finally get the engine to turn over. When I would try to start the car within ~45 seconds of the engine turning over, it would start normally. If I waited longer than 45 seconds, it would not start.
After talking with Dennis about this, it was suggested I bypass the fey fob lock out, which I did. The car, however, still has the same problem, and I have only been able to get her started once in the last 4-6 months. The battery is fine.
Dennis also suggested I bypass the clutch lockout, which I have not done as this seems to be a bit more difficult.
Any thoughts/ideas as to how I can get this fixed?
Thanks.
