Bly,
I decided up front to use power steering on my car and it worked out great. From NASCAR to exotics, most are using PS today. My system uses a Mustang II power rack. I used a combination of a late 60's bracket and a 93 Mustang GT pump with a V-belt sheave. The new pumps still use the same diameter shaft as the pumps from the 60's. My only change will be to drop the pressure with a new valve as the steering is a little too light. Heidt's and others make a valve. I say go for it!
Gary
