  #89 (permalink)
Old 10-07-2008, 08:59 PM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
Originally Posted by Hans-Olof Blom View Post
Eljaro,
This is very interesting. I have a 482 engine that I plan to put a Weber 48 IDA set-up on.
What cam are you using?
What chokes are you using?
my cam has the following specs:
duration- intake 242, exhaust 248
LS- 110 degrees
lift- .645 intake and .635 exhaust..
I have run the webers successfully with the 40mm chokes, and am now in the process of tuning the 42mm ones. Takes a totally different emulsion tube (the F14 is no good any more!). If the weather this next weekend allows I will be fine tuning and will post the results.
Nothing sounds better than a Cobra in a Tunnel !
