Old 10-12-2008, 07:46 AM
Omathisen Omathisen is offline
Cobra Make, Engine: ERA, 351
Default slave hardware
Hi,
Thanks. Hope you can help me with a couple of more things:
Is the slave held in place in the bracket by the snap rings only? Is the screw on the outside of the bracket for holding the return spring only? In other words that screw does not serve to hold the slave in place as well? The nut for the screw came off in the process of taking the old slave out so now I have to weld that in place or get another bracket from ERA.
Also, the soft connection to the slave -- does it have washers on both sides? Any particular washers. We had a leak issue as we bled the new slave.
Thanks again.
