Boy, did I mess up! HELP!!
Well, I screwed the pooch tonight. I just finished putting on an 11" brake kit, bled the brakes, everything was fine. Then I topped off the front fluid level with LACQUER THINNER! I picked up the wrong can off the floor, same size and shape. I proceeded to drain the front lines and ran a quart of brake fluid through them. Now, does anyone know if I messed up any seals or other vitals by doing this? The fluid I drained out was about a half and half mixture. I did'nt touch the rear brakes, I think they'll be ok because I have a dual reservoir. Any info or ideas would be welcome. Thanks........Jim
