Old 10-13-2008, 04:29 PM
Bobcat Bobcat is offline
Sammy .... CONGRATULATIONS !!! You might want to talk to Doug at ERA . I had them run a 1/2" fuel line on my car as my engine builder said I needed it . If I remember correctly , it`s aluminum and fairly easy to shape and form . You will need to flare both ends AFTER you put the fitting over the line ... but Doug can walk you through that . You will also have to change your fuel pickup as it is 3/8" .
Again ..... way to go !
