Jimbocobra,
The heat shield is for the clutch master cylinder. My setup is for Backdraft and Superformance cars that have another type of slave cylinder setup that doesn't perform the way as designed.
To answer your question, you would have to relocate your clutch hyd, lines up and over the footbox. Add the heat shield for the clutch master cylinder. This should solve your clutch fluid issues, but you still should replace the fluid and a routine basis.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
