Old 10-16-2008, 02:54 PM
ddcobra's Avatar
ddcobra ddcobra is offline
Thumbs up The new Concept Python RR
The new Python RR will be avalible for summer 2009
V8 Application:
Type:.................................. 5.4-liter Supercharge
Block Material:....................... Cast aluminum
Cylinder head material:............ Cast aluminum
Valvetrain:............................ 4 valves per cylinder
Fuel delivery:......................... SFI
Compression ratio:.................. 9 to 1
Horsepower:.......................... 605 @ 6200 rpm.
Torque (lb-ft/Nm)................... 550 @4400 rpm.
Wheelbase (in/mm):................ 98 / 2498.2
Width (in/mm):........................72 / 1764 front 77/1955.8 rear
Height (in/mm):.......................47.7/ 1211.5
Front Track (in/mm):................62.4 / 1584.5
Rear Track (in/mm):.................62.6 / 1589.5
Curb Weight (lbs/kg):...............2100/ 955
Weight Distribution (f/r):...........50 / 50
Wheel....................................18x9.5F 19x12R
Tire size.................................265/40-18 345/30-19
All CNC Body for perfect fit
