Old 10-18-2001, 12:57 PM
MRITTER MRITTER is offline
Cobra Make, Engine: Factory Five W/ R block Stroker, Twin Turbos.
I had a ride height difference on my Cobra after about 1500 miles or so. Lower on the driver's side, I guess due to the fact that I was driving without a passenger a lot. The driver's side was about 1/2 inch lower. I just adjusted the spring on the rear by 1/4 turn (1 full turn = about 2 inches) and on the coilover on the front. Has remained even now for an additional 2000 miles.
After trying to measure the distance from the frame to the floor (on my FFR that is only 5 -1/2 inches, I verified that I could do the same measuring from the floor to the top of the wheel well flare and get the same result. Much easier. Of course, if the body is not symmetrical that might not work for you.
Later,
Mike
