Thread: Dyno run
  #48 (permalink)
Old 10-17-2008, 03:39 PM
Doubledip's Avatar
Doubledip Doubledip is offline
Send a message via ICQ to Doubledip
Originally Posted by NASSTY View Post
What can be overlooked is the timeframe of a cobra build. On average it's probably 3 yrs going onto five. Most don't get built in 12 months; perhaps unless you've done it before.
That's probably part of the problem here. The tune was ordered 3.5 yrs ago but most things have a 12 month warrantee. So long after you start driving the cobra the warrantee has expired. Some suppliers understand this, some won't.
Also, despite there only a small difference between the tunes, which at WOT is going to be hard to feel those extra kws, that's not perhaps the biggest problem. As an ICV the vehicle needs to pass an emissions test. If it's running rich at idle and part throttle it won't pass.
this here is not a dig but just a comment for others to read for the engineering side of things. In general if you have a ICV and as we know has to be engineered and now go through emissions testing then you need to fit a late model engine and all the accessories it ran in the production vehicle. This would mean a MAF so for starters the mafless tune would be no good boxhead recieved... so then regardless the tune running rich wont pass..
It would be better for those that are going through this stage at the time to get in contact with the end tuner and say once i have passed engineering , emissions blah blah blah and i am driving it i will be in for a Dyno tune. Then ask them to supply the standard tune in the ecu that the factory car had (all be it for VATS and fan temps and speedo ), but still retain the MAf O2,s etc... This way the engineer will be happy and so will the RTA/emissions testers.
Also i would feel it is best that these sorts of things are left right till the time they are needed... as earlier pointed out warranty runs out on a lot of things when building a ICV (a computer wont stop you building the car), so why help it by buying a computer and tune when you know it wont be used till 2.5 years down the track at the earliest.. the tuner could have even gone out of business before you first get to turn the key.
As I said this is just a warning for all not a dig at what Nasty has said.
www.ultimateconversionwiring.com.au
_
