Thread: Brake fluid
Old 10-20-2008, 12:42 PM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
If you change to a synthetic, make sure you completely,... drain the old fluid out, as they do not mix well.
Since I/we, don't drive our cars regularly, I suck out the master cylinder fluid and add fresh before winter. Water/humidity is the worst enemy in braking systems. I try to use all the fluid from the can because once opened, moisture sets in. If I only use half of it in my cobra, I'll add the rest in my other cars.
Regards,
Kevin
