  #557 (permalink)
Old 10-21-2008, 07:09 AM
capteddie's Avatar
capteddie capteddie is offline
Cobra Make, Engine: CRII 351W/408 Stroker
Send a message via AIM to capteddie
Jerry,
Thanks for chiming in on the our build thread. At times its been a great source of debate and learning. I'm going to stay away from the tubing size issues. DV pretty much has a form of artistic freedom to do what he thinks is best with the car build. Plus I'm not overly concerned with weight, but if I was. I could always lose 20 or 30 pounds to make up the difference in tubing weight and probably would be good for my health
I probably will need to talk to you after the car comes home to see about switching out the gearing in the rear end. Currently its running 3.73 and DV thinks with the automatic trans, I should drop down to around 3.10.
Thanks again!
"the other ed"
