Old 10-21-2008, 05:01 PM
ddcobra's Avatar
ddcobra ddcobra is offline
Thumbs up For US Customer best price ever !!!
Best price ever 24500 CAN = 20500 US (exange rate)
The EVO5 bird cage alu. floor Complete kit gives you everything you need to build your car
Frame:
Complete jig-welded original style 4” round tube frame. Includes all mounts ready to accept small or big block Ford .
Comes powdercoated in gloss black and silver suspensions parts
Includes three point SS roll bar
Includes mounts to accept passenger side roll bar.
Body:***INSTALL***
Hand laid 3/16” laminate composite body and panels made with vinylester resin. COMPLET BODY DOOR,TRUNK,HOOD WITH HINGES.
Complete Front Suspension:***INSTALL***
Unequal length a-arm control arms with QA1 coil-over shock suspension.
500lb. black powdercoated performance springs
Adjustable upper control arms with ball joints
Lower tubular control arms with ball joints
Complete Rear Suspension:***INSTALL***
High-end IRS deluxe rear suspension with QA1 coil-over and Ford 8.8” 3.08 gears.
Complete Front/Rear Brake Kit:***INSTALL***
S/N 95 style spindles and spindle adapter bracket
Front Brakes, Ford 11” front rotors w/calipers, brake pads
Rear Brakes, Ford 10.5” rear rotors w/calipers, brake pads, slider and caliper axle mount brackets.
Russell stainless braided brake line, front and rear w/mount clips, banjo bolts and brake line mounting fasteners
Pre-flared 3/16” brake line and brake line T-adapter
Lokar emergency brake handle, fasteners and cable
Complete Steering System:***INSTALL***
Bump steer kit
15:1 Manual steering rack w/inner and outer tie rod ends
Polyurethane steering rack bushings
Steering rack shaft adapter 9/16-26 spline
Flamming river steering columb and shaft
14” Vintage wood and aluminum steering wheel
Complete Fuel System/Parts:
Aluminium fuel tank
3/8 Fuel lines, connectors and filter
140GPH black fuel pump
Cooling System/Parts:
16''Electric cooling fan
28''x19''Aluminum radiator
Engine Accessories/Side Exhaust/Mounts:
Engine/Transmission mounts (select 302/351 or 4.6L, or 390/427/428, or 429/460)
Exhaust and headers,(select 302/351 or 4.6L, or 390/427/428, or 429/460),
Gauges and Dash and Electrical Assembly:
427 style aluminum dashboard
Padded dash cover, black vinyl
EZ wiring harness
headlight switch, 3-position turn signal switch
Dash indicators, Red, Green, Blue dash lights
Complete set of 7 Autometer cobra gauges, w/connectors, terminals and installation kit. Includes the following gauges:
Speedometer
Tachometer
Oil Pressure Gauge
Water Temperature Gauge
Fuel Level Gauge
Voltmeter
Oil Temperature Gauge
Complete Interior Accessories:
Authentic 427 roadster seats, black vinyl w/fasteners
5-point harnesses. 3” wide driver and passenger, frame mounted
Complete cockpit carpet set, black all-weather
Lokar Emergency brake boot, black vinyl
Authentic interior rear view mirror w/fasteners
Original style door latches,
Authentic 14” wood and aluminum steering wheel
Exterior Accessories and Lighting:
Wiper kit
Authentic Chrome-on-Brass vintage windscreen, tinted with side bars and fasteners. DOT safety glass compliant
Authentic 427 three-lock set including T-trunk handle, L-shaped hood handles, cam wedges
Authentic 3.5” gas cap, polished cast aluminum
side louvers.
cobra badging nose and tail
Original style headlamp assemblies, including buckets,headlamps, trim rings, and fasteners (DOT approved).
Original style British front amber turn signals, and red rear tail-lights
All lighting is DOT approved.
Complete Pedal Box and Components:
Tilton triple padal and master cylinders
2 x 5/8 Master Cylinders
1 x 3/4 Master Cylinder
Price: 24500$ CAN. = 20500 US
