Robert,
If you remove tire it's the best. Then remove allen bolt and pull off rotor. Adjust star till you can still get rotor on but when you pull handle rotor gets tight and you can't remove. Myself pulled handle up two clicks so they wouldn't be too tight then adjusted star so I could just get the rotor back on. Do both sides the same way.
tom
