  #35 (permalink)
Old 10-28-2008, 11:21 AM
davids2toys's Avatar
davids2toys davids2toys is offline
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
As I said in my post, about 900cfm, that is just about twice what the turkey pan /air filter will flow!!! Then add the temp reduction, it is a no brainer...the trick is making it look good in our Cobras!
Where exactly did you get that quote from, can you post a link so I can read the whole thing.
Originally Posted by Don View Post
David:
I had considered a similar system, but had not actively pursued. In the Spectre news release:
" Better than a turkey pan these innovative kits bring the advantages of cold air induction to any enclosed engine, like a Cobra for example. In fact, for every 10 degrees F that the incoming air temperature is reduced, the engine will gain 1.5-2.0 percent in both torque and horsepower "
If you arrive at a configuration from Spectre, please post the part numbers etc., etc.,
.........thanks
