I have a tight fit as well, and found that studs are much easier to handle--install is much easier, and just use a hi-temp nylock to hold the header--they will not back off like a normal bolt. Take care of this ASAP--can cause a burnt valve very quickly! You may have to loosen up the motor mounts and raise the motor slightly.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
