No way the tunnel port 427 heads fit under the stock EM hood--you may have to call EM and get their modified hood for 460 cars, because that hood has a wider and slightly taller scoop. That may fit, but even it will be tight. The dual quad tp intake is set up as a tunnel ram, and is about 4-5" taller than the OE medium riser intake, which is about as tall as the common low riser performance intakes. If you have Ganahl's "Ford Performance", look on pp 57 and the tp intake is pictured on the lower left, below a MR intake. Are you sure you want to run this motor anyway?? Needs a lot of RPM to develop power.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
