The gauge comes out without removing the dash. You can remove the steering wheel. Hardest part is not scraching it taking the center horn button off. Use some fishig line run around the crease in case silicone was used to mount it. A small hand can probably replace the gauge with just removing the tach to get access. You probably have lost part of the gas charge in the bulb and Bourdon Tube, so it reads low. It will eventually stop reading completely. You already have learned more about your new car then many others.......Isn't this fun?
SPFWiringDiagrams@Comcast.net
