  #24 (permalink)
Old 10-31-2008, 06:41 AM
MEvang MEvang is offline
You can move the turn signal switch around as shown, but beware of a few things. First the wires to the switch are zip-tied tight against the steering column under the dash. You will need to cut a few of these ties loose in order to move the switch.
Second, you will have to spin the turn signal cancel cam also or it will not cancel correctly.
Therefore you might start this by removing the steering wheel and hub assembly. Looking at the cancel cam position and turn it 180* along with the switch.
I do have detailed instruction on this Email me and I'll see that you get them.
Mike E
Dynamic Motorsports
mike@dynamicmotorsports.net
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
