Old 11-01-2008, 06:57 PM
Jim Kellogg's Avatar
Jim Kellogg Jim Kellogg is offline
Cobra Make, Engine: Superformance MKIII #887, drive it a lot!
Send a message via Yahoo to Jim Kellogg
Most likely the coupling clamp bolt has loosened up.
Pull the bolt that clamps the coupling to the shaft, and check to make sure that it hasn't been overtightened and damaged. The bolt may just be loose, but if you are unsure of it's condition, just replace the bolt.
Jim Kellogg
Breesport, NY
