Old 11-04-2008, 11:59 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
We use Teflon pipe dope on race engines with satisfactory results. The problem with tape is if it's used improperly when sealing fuel or oil lines, i.e., taping the leading two threads, little pieces shear off and get into the system. This may plug oil galleys or fuel passages. Consequently,the FAA restricts it's use.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
