Originally Posted by MEvang
You can move the turn signal switch around as shown, but beware of a few things. First the wires to the switch are zip-tied tight against the steering column under the dash. You will need to cut a few of these ties loose in order to move the switch.
Second, you will have to spin the turn signal cancel cam also or it will not cancel correctly.
Therefore you might start this by removing the steering wheel and hub assembly. Looking at the cancel cam position and turn it 180* along with the switch.
I do have detailed instruction on this Email me and I'll see that you get them.
Mike E
Dynamic Motorsports
mike@dynamicmotorsports.net
and thank you Mike, for taking the time to help me out and sending me that info, even tho the car was not sold through your dealership, you still helped me out, i can imagine how great the customer service is you offer to your customers.
thanks again Mike
