  #31 (permalink)
Old 11-05-2008, 08:03 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
looking at a small through the hood problem here. could take out the spacer but it would drop only 1".
finished at last, nothing to do here. will probably see in the next week if it is going to run, in the meantime, looks real good. gotta dig that homemade alt. bracket.
i know it's not small block, but just have to install the seats here, everything looks to be done. little polishing wouldn't hurt. the dash is split just right of the steering column so i can take it out easily, not bolted in now case i have to reroute wires. with the wires using plugs it is easy to install and remove. it's the fasteners at the top inside that take finageling.
