If you can get your car on a lift or jack stands, do a good visual inspection. All the bolts in the frame/suspension come from the factory with red paint marks so it's easy to see if any have loosened ( very unlikely). Also, check the bolts on the flange connecting the drive shaft to the rear end.
You should safety wire Your spinners if they aren't already. That provides a very easy visual inspection method.
