  #21 (permalink)
Old 11-05-2008, 01:11 PM
Ant Ant is offline
Default Synthetic gear lube
Heat kills, so the problem with transmissions and rear ends is check the temp and if it needs coolling, you can use synthetic lube for some additional heat capabilities if recommended, or fit a cooler!!
I run an 8.8 IRS with Eaton posi with carbon clutches, Eaton recommend 80/90w mineral oil with the Ford/GM additive "NOT SYNTHETIC" the same thing would apply for the Ford LSD, Jaguar Thornton power lock and original type Cobra diff. I wouldnt take any notice of reps from oil suppliers saying their synthetic product can be used especially in LSD units, they mostly dont know, and I see guys here get their hotrod Cobra's up and running the first thing they do is put some Redline etc fully synthetic in the LSD..............!!!!!!
Toploaders, the race guys here have used ATF fluid for racing to make easier shifting (my road car still has ATF for 440,000K's) and no problems. With my Jerico they recommend any good quality synthetic 75/90w oil, but it hasnt got syncromesh which maybe affected by synthetic.
Synthetic isnt good for every application, some engine builders dont like full synthetics, and often recommend semi-syn or mineral oil. I used to think because more money is spent on synthetic lube I would leave it in my vehicle longer, to get my moneys worth, but it is probably better to be changed more often to get rid of any contaminants in the oil.
A J. Newton
The 1960's rocked!
