Old 11-08-2008, 11:15 AM
Barry_R Barry_R is offline
Ford used internal and external casting cores with darn near reckless abandon. The mirror image 105 only means it was cast at the MCC foundry. It does not designate heavy duty in any way. The 352 designation is usually - but not always - found on blocks cast at the Dearborn Iron Foundry (DIF). The center drain is common and does not mean much. The vertical ribs are most common on later service blocks - but again are not definitive. The 4.130 bore and a sonic check are your best friends here....
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
