Originally Posted by MaSnaka
What I was trying to find out was...were the 428's that came from the factory installed in a Cobra, built from the same blocks used for 390's or are the blocks different and only used to build 428's?
John, the simple answer here is No. The 390 and 428 blocks are different even though they may have the same or similar casting #s. There must be 200 variants so there's no need to go into them here, but the books that you ordered will shead some light on the subject as well. I went through this vertical learning curve just a while ago as I started sourcing parts for the 428/462 that I'm building for BDR687.
Steve
