Old 11-10-2008, 10:30 AM
767Jockey's Avatar
767Jockey 767Jockey is offline
Originally Posted by Jerry Clayton View Post
We use ATI super dampners on our builds---for the ford FE the bolt pattern on the dampner is for a bbc and you'll need to offset drill the pulley holes .050 to use original pulleies---if you want to use later or aftermarket just use with a chev bolt pattern
The dampner that I would stay away from is the fluiddamper---every time I see a broken crank it has a fluid dampner on it---
Have you got back to the 767 yet???
Thanks, Jerry. No, I'm still in the 737. Can't hold the left seat in thew 757/767 for quite a while yet.
I'd like to use the original pulleys without messing with them. What can I use that is decent and can use the pulley's that I have now?
