  #128 (permalink)
Old 11-10-2008, 04:28 PM
Great Asp's Avatar
Great Asp Great Asp is offline
Cobra Make, Engine: SPO 2715
E, yup, thankfully, my car is up and running. Where does the computer get mounted and I assume a sidepipe is drilled for the O2 sensor? I'm just trying to assess the difficulty factor in hooking up one of these setups. What was the "fitting" all about? Did they have to mill the intake and/or heads for a proper fit?
Well, the box for the injection system will be under the glove box, and the 6AL will be in the engine compartment, "unless" they will both fit under the glove box.
I am going to get the small individual runner K&N filters, and have a chassis tune for both, no filters, and the K&N filters. I will not be using the "booties".
The side pipe is drilled and a bung fitted (welded) between the muffler and where the collector is, about as far back to the muffler as you can without getting into the muffler.
The fit between the intake and and the block and heads was not "true" to my understanding. I'll check with KC and see if I can get you a better explaination. But it could not have been much as it was only 180 bones. I'll check.
E
