Doug, if you have an empty fuse slot in the bank, put ACC to one side and run the other side to the 1/4 inch spade lug. Put a 5A fuse in and she should be ready to go.
Let her sit over night and then, in the morning, go out and push the throttle once. The choke should close and be just closed, not slammed shut. Adjust the tension by loosening the three T screws in the side and turn the black can. If you take it off, you have to align it to get it back on.
Anyway, start the car and run it. There are like three stages of fast idle, you can adjust each one. Once set, take a tooth pick and dab ( dab mind you ) a bit of loctite blue and on each fast idle screw...all two of them.
Should take about 3 minutes to heat the choke coil and settle to warm idle.
Hope this helps!
