Old 11-11-2008, 10:03 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Hey cobras,
You got my wiring diagram?
It's all on there...
Email me if your having problems following it...
The small compressor would work better in an emergency if you used the larger clips connected right to the battery. That's a lot of juice being pulled thru the accessory plug circuit. Remember to have the car running too, or you'll have a dead battery and a flat tire...
Also, newer cars have a accessory plug that is always "LIVE"
Pre #1040 cars had an accessory plug powered thru ignition switch.
It's easy to change either way....
SPFWiringDiagrams@Comcast.net
