Old 11-12-2008, 12:40 AM
PANAVIA's Avatar
PANAVIA PANAVIA is offline
I would do a "covering" back to the firewall and leave them natural under the dash.
or you could put a bulkhead connector and have AN lines forward to the pump/manifold and rubber under the dash.
keep in mind that steel braided lines are electrically conductive and if there is an open terminal or wire to a 12V hot then you can have issues. also steel braided line (non covering, actual steel braided line) is a big pain to get to seal with hose clamps.
Steel braided lines are also abrasive and will rub through wire wrap and insulation as well.
--Steve
