Old 10-22-2001, 01:46 PM
Flyin_Freddie's Avatar
Flyin_Freddie Flyin_Freddie is offline
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Can't say for sure, but I have seen switches with separate connections for each side of the car. One would think there would be a terminal connected to a relay, then the relay would be connected to the circuit and to the load (lights, etc.). But, I've seen separate terminals for each fusible circuit, ie: right side of the car versus left side.
Check the switch and see if any terminal is touching another and causing the short. But BE CAREFUL, the terminals are hot even with the ignition switch off in most cars. You can cause a real fireworks show if you're not careful. Make sure you've got some spare fuses on hand...you'll probably need 'em....ask me how I know this!
If you can't find the problem in the switch, disconnect one terminal at a time to troubleshoot. If something else goes off and stays off, then that's not the bad circuit. Eventually, you'll get to one that makes no change to your problem - THAT'S THE ONE! Then all you've got to do is figure out what's wrong with that one...I'd bet it's touching another terminal and causing a back circuit, short, or ground problem.
Frustrating as hell, I know, but I don't know of another way. Start at one end of the circuit and test until you get to the end of the circuit...jumping around will cause your to lose your mind...don't ask me how I know about THAT one either!
Don't forget about the fireworks show...it will happen...trust me!
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
