1:8 rockers?? should be 1.73:1 if using the 429CJ/SCJ set up, and 1.75:1 if using 'plain' 429/460 parts. If you are using 1:8's, you should be using a slightly shorter pushrod. The 1.8:1 are actually BB chevy ratio. I double checked mine, and are 1.73:1. This may be the source of valve problem--not float, but bind. Can be VERY damaging to a motor--esp the camshaft & lifters. I found a couple of cam mfgs that sell 1.8 rockers, but a footnote says you MUST use thier pushrods?
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
