Cobra vs Viper
I think you have to take the number of whacks you used to tighten the spinners on the left side of the car only multiply it by the square root of the age of the driver divide by engine displacement add 2 for wind drag subtract the wattage of the head lights unless they are HID units in which case you have to factor in the spring rate for the pressure plate.
In short order the answer will be self evident.
By the way, for each 100 lbs of weight, the general rule of thumb is you should add or subtract (depending on heavier or lighter) 0.1 seconds from the quarter mile time all other things being equal (which they are not).
Wow! I'm even more confused. More beer and fresh horses ...
Ed
