Doug,
Great drive and fun breakfast!
Sorry to hear about the noise, a compression check will tell you a lot ... maybe a valve lifter or cam lobe is the problem? Just guessing at this point. Since you have the valve cover off, maybe crank the motor a bit an see if it looks like the valves are opening and closing properly.
- Tim
