Cdog;
All good info so far. I would also check valve spring pressure......First check installed height and then valve spring seat pressure at that height. I would not run less than 125 # for a 6000 rpm motor or you may well have valve float as well as valve bind,check out these things and I think you will find your problem.....
David
DAVID GAGNARD
