Berm, how do you seal the lower edge? I see by eliminating that lower lip you didn't have to trim the throttle arm on the carb. I have seen another custom drop oval base like yours where more trimming was required. I was considering doing something similar but was concerned that dropping the base too far below the same plane as the carb air inlet would disturb/restrict the air flow. Have you dyno'd your results with and without?
