Go to Finsihline
http://www.finishlineaccessories.com...699403ffcc43ba
Get their
oil cooler and shroud, when you order tell them it is for a Backdraft, they make a shroud especially for our cars, the others will not fit.
Then mount it but do not hook it up. (run dummy lines) Unless you are pushing over 500RWHP and track the car in 100 degree temps you don't need it.
If you ignore my advise and hook it up be careful in temps under 80 degrees as the
oil will not get hot enough to burn off moisture that accumulates in the crank case.
So best advise, if you insist on the look, go with an
Oil Fooler (a cooler that's not hooked up)
