Thread: oil cooler
Old 11-20-2008, 10:12 AM
Bob In Ct's Avatar
Bob In Ct Bob In Ct is offline
Cobra Make, Engine: SPF - 351W, 944 non-turbo
I have the stock oil cooler on my SPF. If the temperature is below 60 degrees or so I run the cooler with a piece of plexi in front of it (you don't even see it) or the oil will not get to 180. If the temperature is between 60 and 90 degrees I run it partially blocked with a piece of plexi. Above 90 I use the whole cooler. I try to keep the oil at a minimum of 180 degrees.
Bob
