Skip,
I did this myself and it was easy and cheap. First find out what gear you have. My car came with the 3.6ish gears. If you are ok with the gears you have its very simple. Find a used LSD on e_bay or Craigs list or from a salvage yard. I got mine from a salvage yard. Just swap out the lsd for the open. Your must make sure that you use the end caps that the axles bolt to and shims from the third member that the gears came from. This is what sets the gear pattern. There are shims between the end caps and the housing, make sure that you that the end caps and shim stay oriented left to right. The other issue is the speed ring. Just make sure the speed ring matches the gears that you use.... This cost me less the 300 to do the whole swap...PM me if you need anything....Mac
