Problem Identified
I had a billet roller cam installed from Crower as part of te engine rebuild three months ago. At that time my builder checked and then double-checked with Crower who insisted we use a steel distributor gear. When we pulled the distributor the steel gear we found it was severely worn and abraded in places down to knife-edges, allowing the timing to slip. (the cam was harder steel and not worn at all) A third call to Crower resulted in the recommendation for a bronze distributor gear which we installed. Its running like a top now.
Although I've heard on this site that bronze distributor gears need replacing every 1000-2000 miles, my builder says that is not the case that they should give good wear. Anyone have comments on this? Thanks.
Bob
"All that is necessary for the triumph of evil is that good men do nothing" - Edmund Burke
