i just had problem on new build with dist. turning. the gear was too low on the shaft. with the dist. in hand there is a little up and down movement in the shaft, you want that same movement installed. if after installation you don't have this movement you're bottoming the gear in the block and your dist will turn and prob try to eat the dist.teeth.
