Old 10-23-2001, 12:12 PM
Cal Metal Cal Metal is offline
Original Shelby Owner
The advantage of the Toploaders is that the shifting rails slide through bosses cast internally in the case, as do the shifting cams. A little more trouble to assemble, with the variety of springs and detents that have to be installed, but it does do a good job of shifting and keeping things together. If you decide to eventually go the TL route, give David Kee a call. He can be found under the talk forums.
