Old 11-26-2008, 07:18 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Going the remainder of the way to the heater connections is not that much more hose. But I'm not sure you can make the bend after the firewall. Verify the I.D. of the hose so it slips on the heater connections. Don't put too much tension on the heater connections either with the bends if you replace the entire hose.
Or you can splice it in anywhere you like out of sight.
Regarding the tee, you need to account for all the hose connections; supply, return and circulation.
Post a photo of the front/top of your intake manifold. Let's see if the other connection point is there...plugged.
SPFWiringDiagrams@Comcast.net
