Old 11-27-2008, 04:44 AM
WKB's Avatar
WKB WKB is offline
Cobra Make, Engine: Harrison Cobra, SC540 Roadster
BLWNCOBRA,
It took about 10 months to get it drivable. I mainly worked on it a few hours a night and a few weekends.
It was mainly bolting in parts with the manufacture of a few brackets and installation of heat insulation, brake and fuel lines.
As far as I am concerned I think it is a relatively easy kit to build.
If you have stripped and reassembled BF falcons it wouldn't be difficult building one of these kits.
You will need a sedan as a doner car. The ute only uses a 3 channel ABS where the sedan uses a 4 channel system. The wiring harness will be different and the rear suspension will be needed from the sedan.
Warren
