Old 11-28-2008, 04:14 AM
Default Did you add silicone grease to the bushings
legelmetals Did you add silicone grease to the tubes and both ends before installing? You may also have the bolts too tight on the shock mounts. This will cause this noise also. Make sure that the nuts on these bolts are either pinch nuts or aircraft nylocs. All you want to do is tighten until the side to side play is gone, no more. There should be no binding or drag of this joint. Try this and see if the noise goes away. Make sure the grease is water resistance. Rick L.
