I did the mod and it ruined my carb. I used a 1/16" bit and it was too big causeing a huge vacuum leak at idle and basically shutting off my idle circut. if you're going to do it make sure both holes are in the exact same posisition, and you use a 1mm bit. As I further researched it there are hundreds of horror stories of ruined carburetors form doing this mod incorrectly. I'm in the process of trying to find a way to plug the additional holes now.
